hight iat2 temp
hight iat2 temp
so ive got tuned today(wideband)and my car reach 168f at 5800rpm so the timing drop to 15deg
my ic pump is really good
my mod are in my signature
could it be my piping that reduce the flow??
whats the ambient temperature outside. and are you sure your everything is bled correctly, double checked to make sure the IC pump is working 100% and how many right angle bends are in the tubing.
outside temps was 25 celcius(77f) my ic pump work flawlessly and what mean >>>>>> how many right angle bends are in the tubing<<<
so ive done a new job on my piping patern...now the coolant pass in the zzp before the oem and i removed all the right angle bends in my set-up....and still got hight iat2 temp(159f)better than before but still hight...so i will try a new pump...im on the original ic pump(88 000km)so could it be my issue
ill try tonight
temp outside was 25celcius
ill try tonight
Sean Cummings
03-09-2018 12:26 AM
z28addiction
09-28-2015 12:03 AM
