hissing noise under acceleration....???????
okay, i have a 2005 cobalt ss/sc. for the last few weeks i have been getting a ticking noise when i first start the car. two days ago, she was hard to start, and then she developed a hissing (squealing) noise under acceleration. i was hoping it was the ac compressor, but it seems to be something else. also, she experiences a loss of power, and her gas milage is gone to ****. the check engine light was always on ( i bought the car used), and that was an oxygen sensor, but now the fuel consumption has gone from 9.2l/100km to 11l/100km....? if anyone could point me in the right direction, that would be great. Thanks
Also, if someone could tell me where the timing chain tensioner is, i would appreciate it
it is in need of a tune up, i know that. i just took it out of storage 3 weeks ago. she has 63000km so she is just out of warranty. the hissing noise is what concerns me the most. it only happens under acceleration, and seems to idle fine. i should also say that the ticking noise goes away once the car warms up. i am thinking there may be a vacuum leak, or a leaky intake/supercharger gasket...?
If the hissing noise gets louder as you accelerate then most likly a exhaust manifold leak or where the down npipe joins on to it.
Where does it sound like its coming from you werent to specific ?
it sounds like its coming from the belt side of the engine, but its hard to pinpoint the exact location. the alternator has crossed my mind as a possible cause, as has the ac compressor. but the loss of power during acceleration is what bothers me. it seems like she is starved for fuel under acceleration, past a certain point on the pedal. either that, or loading up on fuel....
Well, friends, i found it. exhaust manifold leak. thanks for all your suggestions. you have been very helpful. I was scared to **** it was the engine. what a relief! I did swap out the plugs and air filter as well. they were in rough shape.
god, its too annoying for me to drive. it squeals like a pig under hard acceleration. at least its not an expensive fix. couldnt really get in there to see if the bolt was loose, or the gasket gone, or the manifold cracked. either way, its better than an engine replacement.
DANRICKARD
10-01-2015 12:08 AM
