Hot air coming out of a.c
Probably need to charge it but you can only tell by hooking up to Test lines and seeing the levels go up and down (or for this matter have very low pressure in both). Do you know if you have a leak anywhere because that would shut the system down from working.
your HVAC controls might be bad. does your compressor clutch kick on when you turn the AC on. walk around the front of the car to check and look in the engine bay and see if the clutch is spinning. if it is spinning, does it keep cycling on and off? check these things. But if it blows cold under a low setting, then the HVAC contols might just have bad wiring and you can get a new one for like 30 bucks on ebay
DANRICKARD
10-01-2015 12:08 AM
OrangeCoba
09-25-2015 06:06 PM
