How to install PCV Valve- LSJ
Hey guys!
So I am in the process of replacing my PCV valve that is located in the intake manifold between ports 2 & 3. and I was just curious as to how to put the new one in, i took the old one out by twisting it with a flat head screw driver, but i didn't know if putting the new one in if you had to twist it, push it in until there's a click or something, or if i just set it in and when i put my intake manifold back on it will seal its self? I just want to make sure i do it right before i put it back on because I'd rather not have to take everything apart again. lol
It will just pop in and be seated, the new ones are much tighter than the old ones due to the new o-rings, so like he mentioned put a little grease or clean engine oil on the o-rings, and they should pop right in.
Quick question as I will be doing this myself Friday or Saturday . Can I just remove the supercharger or do I need to remove the intake manifold as well ? If u have any pics would be a great asset. Thanks
Nevermind , I found a pic showing it needs to be removed. Ugh well least I have 2 days off to learn how to do it.
