I Blew It!!!
Originally Posted by bdwarr6
It depends if you want to go stock, or aftermarket. I have looked at both options and i will say its a bit more to go aftermarket but in myopinion well worth it
OEM Parts
88984129 cylinder sleeve, one per cylinder required.
90537691 cylinder head bolt, M11 x 1.5 x163, total of 10 required.
24407225 cylinder head bolt, M8 x 1.25 x 60, 4 required.
12595961 cylinder head gasket kit, less valve cover gasket. -- this is on backorder*****
93180138 piston ring kit, one per piston required.
12791210 one piston head
11519783 crankcase bolts - you need 20 you cant reuse stock ones
your going to need some marvel mystery oil to oil your pistons with when you go to replace them.
Piston ring compressor
18mm 16mm 15mm 14mm 13mm 12mm 11mm 10mm and 8mm sockets and wrenches
alot of plastic baggies to label what bolts go where
now if you want to go after market which i reccommend
get a cometic headgasket www.cometicgaskets.com
mahle or diamond pistons www.intense-racing.com www.cobaltperformanceparts.com
Golden eagle head studs www.lightingmotorspors.com
all in all to fix it it isnt bad i just bought about every toy you can for the balt i figured i would do it and be in dept for it once
OEM Parts
I will go aftermarket. Now I need to find out what compression ratio I want to use. I have access to ALL tools (I'm an Army Mechanic ). Also while I'm in there I'm thinking of putting a new clutch in there also (SPEC Stage 3+ and flywheel). I'm only praying that my main bearings and/or valves have no problem.
I wish my car sounded/looked like a x-mas sleigh when it blew. I cracked the block, warped the head, and melted the number four piston and my car didn't so much as make a peep.
Actually haven't decided on pistins yet.....Not sure which ones would give me better HP/TQ numbers on blown applications(this is the first sc engined I've owned), and also stand up to the boost I plan on using. I also thought of the spec 2+ but I really don't know the difference between 2+ and 3+ besides the price. I figured they would be a little better but it might be a little overkill for the balt...ALL I know is that I will go with the + versions.
We should make a "blown engine" thread to list how many blew there's. And what products they used. And fitment/installation problems
Wow... just wow...
I know a dozen or more LSJ's with 2.6" or 2.5" pullies. RiceEater had a 2.6 on the stock tune before most people had a 2.8". The only difference here is the complete lack of apparent intelligence on someone's behalf...
There's no reaon in the world that a 2.5" pulley needs some crazy cooling upgrades to prevent the car from blowing up...
Moderator Alumni
Originally Posted by denny
Personaly the MAHL 8:5.1 would be my choice.
If I was going to keep the M62 I would get 10:1 Diamond pistons and use a 2.8 pulley.
If I was going turbo I would get the Mahle.
I just got my block back from the machine shop Schmitts racing they build 150k motors for top fuel drag cars
he made a comment about diamond head's pistons
"These are some of the finest dam pistons I have seen in a while" quoted from the shop owner that builds top fuel drag cars and swears to only use weisco pistons he said hes calling them monday for some demos
TheSandMan
09-20-2015 06:02 AM
2K5SS/SC?
07-21-2006 02:25 PM
