I broke my car :(
I broke my car :(
On the way home from work about a month a half ago (I'm lazy and have been procrastinating) I was on the freeway and gave my car the money shift from 5th to 2nd instead of 4th, fail I know, and after that my car has been running like ****. It sounds like a subaru, but no misfire. My fuel injectors are leaking. All of my cylinders get low compression, and when I'm driving I can hear a small ticking coming from the passenger side of the engine when it's under low compression. I've been daily driving it about 60 miles everyday since then. It's not burning oil and I still get the same gas mileage. Only thing is it sounds like a damn subaru and there is no power anymore. I need help figuring out whats wrong so I can enjoy my car again.
thanks guy.
pull your valve cover and I'm guess it will look like something in this thread...
https://www.cobaltss.net/forums/2-0l...ockers-253088/
Problem solved! Pulled off the valve cover and 2 rocker arms were laying there completely intact. I just loosened up the cam shaft and the tension on the chain and put those jawns back.
is ur power and compression back and everything now??
this happened to me one time in my orange cobalt. luckily it had a fully built motor at the time from wsfrazier so i think it worked out just fine. that and i was only diong like 65 so it was just barely out of 2nd gear.
XStylus
Forced Induction
09-16-2015 06:19 AM
