I lost 10 psi??? I need help please
Old 12-29-2008, 05:28 PM
1badBlueberrySC's Avatar
Originally Posted by Gixxerboy02
Right on man.. good looking out..Any ideas on what the problem might be? I would liketo fix it right but no luck so far...
Read above!
Old 12-29-2008, 05:31 PM
Gixxerboy02's Avatar
Originally Posted by 1badBlueberrySC
Yeah, the 2.7 is a heat generatin' S.O.B. Start the car and make sure the fluid is flowing through the H/E fluid neck!
I will look into that tonight. Car runs fine though. It never runs hot. The supercharger stays cold. Im not one to run my car to death. It hardly ever gets opened open
Old 12-29-2008, 05:32 PM
You has meth so yeah you may want to check your meth nozzle and make sure its clean and spraying correctly... then make sure your H/E PUMP is working.
It could also be a tune issue as well you can limit boost through HPT
Old 12-29-2008, 05:35 PM
Psykostevo's Avatar
Car will never run hot when intercooler pump fails. The intercooler is not linked to your coolant. That's a popular misconception. People think "Oh my coolant is down in temp, it's okay to boost again" wrong, and wrong to assume it's not the pump I mentioned just because the engine coolant is fine. The intercooler fluid is on it's own circulation system.
If you have an inoperable intercooler pump it will make enough heat just sitting still to damage your car. 180* + IAT2 temps during cruising let alone boost. Look into the intercooler pump issue, I am dead serious.....only thing I have ever seen cause your situation and I have seen it first hand atleast ten times now on all the cobalts I work on.
ant fix his issue until he fixes the pump and disconnects the battery.
Old 12-29-2008, 09:37 PM
[QUOTE=Psykostevo;3257159]Car will never run hot when intercooler pump fails. The intercooler is not linked to your coolant. That's a popular misconception. People think "Oh my coolant is down in temp, it's okay to boost again" wrong, and wrong to assume it's not the pump I mentioned just because the engine coolant is fine. The intercooler fluid is on it's own circulation system.
How can i check the intercooler pump??
Old 12-29-2008, 09:52 PM
[QUOTE=Gixxerboy02;3257868]
That small neck at the front of the engine bay with coolant in it? Open that cap and turn the car on... if fluid runs through it, it's fine!
Old 12-29-2008, 10:11 PM
[QUOTE=1badBlueberrySC;3257915]
ok just checked that and it flows. I got under the car and looked at the pump.I could not hear it running. I felt the hoses and they where cold unlike the radiator hose. Meth is working just fine...Im lost
Old 12-30-2008, 10:24 AM
rnjmur's Avatar
I believe there is an actuator that controls the boost control solenoid, you may look into that.
Old 12-30-2008, 02:01 PM
Where is that located???
Old 12-31-2008, 09:35 AM
rnjmur's Avatar
Let me see if I can find the schematics for the boost control system. I have it laying around the house somewhere...
Old 12-31-2008, 11:01 AM
  #36
Psykostevo's Avatar
I'm still thinking your car saw extreme IAT2 temps. Disconnect your battery for half an hour and put it back on to see if you regain boost.
Sl0wbaltSS
11-21-2018 11:11 PM
RaginChopsuey
10-27-2015 01:27 PM
no_ss
10-18-2015 11:58 PM
MrInsanityWolf
09-29-2015 04:54 PM
09-27-2015 08:53 PM
Quick Reply: I lost 10 psi??? I need help please
