I lost 10 psi??? I need help please
I will look into that tonight. Car runs fine though. It never runs hot. The supercharger stays cold. Im not one to run my car to death. It hardly ever gets opened open
You has meth so yeah you may want to check your meth nozzle and make sure its clean and spraying correctly... then make sure your H/E PUMP is working.
It could also be a tune issue as well you can limit boost through HPT
If you have an inoperable intercooler pump it will make enough heat just sitting still to damage your car. 180* + IAT2 temps during cruising let alone boost. Look into the intercooler pump issue, I am dead serious.....only thing I have ever seen cause your situation and I have seen it first hand atleast ten times now on all the cobalts I work on.
ant fix his issue until he fixes the pump and disconnects the battery.
[QUOTE=Psykostevo;3257159]Car will never run hot when intercooler pump fails. The intercooler is not linked to your coolant. That's a popular misconception. People think "Oh my coolant is down in temp, it's okay to boost again" wrong, and wrong to assume it's not the pump I mentioned just because the engine coolant is fine. The intercooler fluid is on it's own circulation system.
How can i check the intercooler pump??
[QUOTE=Gixxerboy02;3257868]
That small neck at the front of the engine bay with coolant in it? Open that cap and turn the car on... if fluid runs through it, it's fine!
[QUOTE=1badBlueberrySC;3257915]ok just checked that and it flows. I got under the car and looked at the pump.I could not hear it running. I felt the hoses and they where cold unlike the radiator hose. Meth is working just fine...Im lost
