Idling problem
Idling problem
-Car will start and sometimes, only has happened twice now, but it will start and die instantly.
-Car idles rough.
-Car gets bad gas mileage. The DIC says otherwise, 32MPG, even after being reset, but it's definitely wrong.
Not sure whats wrong. Plug is fouled? Injector is fucked? Fuel filter is clogged? Butterfly on the TB isn't closing all the way? I have no clue.
The car only has 19,000 miles on it.
The TB is clean. Air filter is clean. MAF is clean.
-Car idles rough.
Try replacing your EVAP emissions canister located directly to the right of your valve cover.
I had a very similar issue, cept. my car would only idle rough or shut off right after getting gas.
Go to your local dealer and ask, or find out the part number and look on gmpartsdirect
I might just bring it in.. I really don't feel like going on a goose hunt, when the car has a warranty.
I'm going to place my money on it having a bad plug or a bad injector.
I would try resetting the computer by unhooking the battery but I was told that doesn't reset it, the Cobalt stores it somewhere in the event the battery is unhooked.
Last edited by xxxxsh4d0wxxxx; 09-23-2009 at 02:16 AM. Reason: Automerged Doublepost
Hey guys I have a 2006 2.2 chevy cobalt and I am trying to change out my spark plugs but when tryig to twist them out the socket wrench won't budge. I am using all the right tools. Does anyone any tips that could help me on this project?
If you think they are seized you could spray wd40 on them and let it sit for a while,but from my experience it doesn't really help. Get a bigger Ratchet!!
If they are that tight you might have a issue and they will strip out.
Aluminum likes to stick to steel(The term for it is galling)
Spark Plug issues
Yeah I using the lefty loosie righty tighty rule. I will probably have to buy this product that is like wd40 but its stricktly for bolts and things that are really tight and hard to get off. But thanks for the idea though.
