Injen CAI
Injen CAI
I had an injen CAI installed back in Nov 06, well it started to rub on the hood mount. After fighting the shop that I had install it and Injen, I finally received my new one and am going to install myself. Anyone else have this problem -- how to fix?
an update to scarlet... You muct have a 1st gen injen intake. You can check by locating the injen badge, if it's on top you have 2nd gen if it's towards the side it's a 1st gen. you can call injen and they should send you a new one (2nd gen) so i've heard..
no problem with shop. but the injen has that problem. they have fixed it with all the new ones that are bought. it wud dent it big time and put a whole in the intake piping..goodluck
yeah i just intalled mine a couple days ago. when i went back to look at at yesturday i noticed that it was scratched on the injen emblem and part of the intake. i think im going to try and grind down part of that hood mount and then call injen for a new emblem. my install went fine(no jerry rigging or cel's) and that is the only issue.
Tis has been an ongoing problem and if you e-mail Injen you will get no response Here is a link to what I did to fix mine https://www.cobaltss.net/forums/appearance-48/looky-looky-57496/ Good luck you may have to notch the piece of framework to prevent it from happening again, and no you won't damage the structural integrity of your car...that part isn't weight bearing Also here is a link to the original Injen problem link https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/now-victim-injen-cai-woes-30690/
do you have a number to reach them.. I am finding the same on mine and am pretty pissed.. I also threw a CEL today but reset it and hasn't come back since... But a # for INJEN would be a great help to me and everyone else i'm sure...
