Installed long tube header, now having issues
Hey guys, I just installed the Ottp long tube header on my car now my car is idling funny when I hit the gas. In also getting 190 misfires and a blinking check engine light . Code is p0036 I also installed zzp ignition coils... Which might be the cause now that I'm thinking about it. Other relevant mods are ported head, tvs with 2.9 pulley, and Siemens 80lbs injectors. Also the Ottp header didn't come with a spot for my rear o2 sensor so I just left it off. I assume that when I had my car tuned the tuner said that he turned it off could that be the issue? Maybe I need to have the tube redone? Any help is greatly appreciated.
It was the coils! I have codes for the 02 sensor still but those can be tuned out. Guess I need email zzp about these ignition coils
But the car will at least hold idle, still need to get tuned for these long tubes once I get the full exhaust welded on this week
Changing out the coils helped a lot but would a combination of the primary o2 sensor being relocated and using a o2 extension harness affect my car? Also going from catted to catless. Car still dies on deck and fuel Trina are all over the place
The following 2 users liked this post by Omiotek:
blueLNFftw (04-18-2016),
Haven07 (04-18-2016)
Success!! My car works now! Didn't need to cut my harness just managed to get enough slack out of it to connect the sensor to the harness. Tomorrow she's off to exhaust shop to have the rest of the exhaust welded on
redssna
03-15-2016 10:36 PM
