Installed Stage 2. Goes into LImp mode HELP!
I just installed a ZZP stage 2 kit on my 06 lsj.
Put the 3.0 Pully with the #60 injectors, shorter belt.
After installation started my car and it instantly went into reduced power mode. Car ran extreamly bad, basically no acceleration. Check engine light came on and got a TPS performance (or something like that ) code. Doubble checked everything and all my connections. Everything was good.
The PCM that ZZP sent me was missing the tabs on the middle connector for the hold down.
I replaced the PCM with the Stock one. Car has troubble compensating for injectors, but no codes are thrown. TPS reads fine.
What should i do? Does this sound like a PCM problem or what?
