issues after installing OTT Stage 1 kit, key pads, Econn
well i have the car finally runnng, hub is fixed, everything is on and running, it ran a bit rough on the start because i guess anti freeze got in the motor threw the injector hole during the coolent leak when takign the fuel rail off. But now ...... yes more issues, my key pads dont work and my security light doesnt come on, but the one pad will unlock the truck and if u have the car running and u hit lock on the same pad the doors lock then unlock, how do i fix this? and another my mpg's are at like 9 when i first started driving, so i hit reset now im at 40 mpg's, help please?
It wouldn't even turn over if you have to do the security re-learn. The light will just stay on on the dash.
And to do it you leave the key on the "on" position(not started) for a little over ten minutes or UNTIL the light turns off. You have to do this three times without opening any windows, doors, trunk...etc.
Do not try to start it until after the third time. It should fire right up ... Did for me.
Sean Cummings
03-09-2018 12:26 AM
