Just Another Coolant Loss Thread...
Old 09-07-2016, 01:06 AM
  #176
ItalianJoe1's Avatar
Oil coolers leak the other way, oil into the coolant. Oil pressure is always higher than coolant pressure.
They do fail, but you'll have slimy oil filled coolant and clean oil.
Old 09-14-2016, 10:42 AM
  #177
jmix's Avatar
I just read this whole thread because I just had to add a little coolant to my car and I can't find any visible leaks. I'm not getting a good feeling about it.
Old 09-14-2016, 10:50 AM
  #178
hawkssoccer11's Avatar
what year is your car?
Old 09-14-2016, 11:15 AM
  #179
jmix's Avatar
06 SS with 150k.
Old 09-14-2016, 11:29 AM
  #180
exninja's Avatar
It's just a top-off. You're fine.
Old 09-14-2016, 11:30 AM
  #181
^This
Old 09-14-2016, 11:36 AM
  #182
jmix's Avatar
Hopefully but I think I had to add some 6 months or so ago. Time will tell I guess.
Old 09-14-2016, 11:37 AM
  #183
exninja's Avatar
If you're really worried about it then get a sample and send it to Blackstone labs. They'll tell you if you have an issue.
Old 09-14-2016, 12:05 PM
  #184
jmix's Avatar
That's my plan when I change the oil again. Unfortunately I just changed it like 500 miles ago.
Old 09-14-2016, 12:27 PM
  #185
exninja's Avatar
You can get a sample before then. Just be careful opening the drain plug. Or waiting would be good to get more data.
Old 10-10-2016, 03:16 PM
  #186
GreenStang's Avatar
Update: The sealer they put in has stopped the leak completely! I've drove the car about 500 miles I'd say and I've had to add absolutely no coolant it's still full right where I filled it up too.
The sealer they used was Solv-Tec ST5501 K Seal Permanent Coolant Leak Repair.
Here's a link to it on Amazon: https://www.amazon.com/K-Seal-ST5501.../dp/B001QT9KO6
Old 08-23-2023, 01:07 AM
  #187
hatrik8's Avatar
Thanks !
I read this thread. I have a similar problem with my 06 lsj SS supercharged.
My car has 362k and car runs great with no leaks. No coolant in the pan but maybe a little in the valve cover because it has a bit of a film on the cap. At this point I just want the car to last as long as possible. I’m going to try this leak stop and see if that helps. Some days I drive 300 miles and lose no coolant. Other days I have to top it off after 100 miles.
thanks for posting this saga. Lol
izcain
Tuning
01-20-2016 12:28 PM
deviance
Cobalt SS Vendor Reviews
01-13-2016 12:06 PM
Jesus123
01-09-2016 08:25 AM
BA89
01-05-2016 11:44 PM
Quick Reply: Just Another Coolant Loss Thread...
