Key stuck in ignition
i was driving home from work today and pulled into my drive way pulled up the parking break and went to go pull out my keys and they will not turn backward (towards me) only forward. ive tried hitting the break, the clutch, its not in gear, the break is up. i wound up pulling the "crank/run" relay in the electrical box under the hood then disconnecting the ground from the battery, putting the relay in and hooking the battery up but at no point will the key even turn. any one have any ideas? thanks for any help.
-RJ
-RJ
Man this pissed me off when it happened to me. Had the car for a week and it locked up at the grocery store. Im auto so I just pulled the fuel pump fuse but I was so pissed off Luckily I had extended warranty
#cobalthoes
After you get the recall fixed give it another 3 weeks then your key will get stuck again or either in my case take you 40 mins to turn over and start the car.. Recall on the recall FTW
Doesn't matter whether it has an extended warranty or not.. it's a recall.
If you would like for me to check to make sure your vehicle is under the recall, feel free to get me the last 8 digits of your VIN and I'll do that (and send you warranty information as well).
Regards,
Sarah
GM Customer Service
Regards,
Sarah
GM Customer Service
Finally after lightly jiggling the lock for 30 minutes I finally got the car cranked and running. I leaving it running and waiting around for the dealer to open to see about getiing it fixed.
I'll keep you guys updated.
