Keyless entry problems
I have a 2007 Cobalt LT and I'm in a bit of dilemma. My keyless entry/remote start has not been working for some time. I have changed the batteries on both remotes and the performance improved and now it is completely unresponsive. My alarm used to go off when I would manually unlock the door but that does not even go off anymore. Not sure if it is a fuse or something I am not thinking about. I cannot find the fuse even looking through the manual several times. Does anyone have the same problem and if so a solution?
Also had this issue. The connection to the battery inside the fob had come lose from the board. Rigged mine with tape.
Posted from Cobaltss.net App for Android
Keylessfix - Home
I had the same issue. Got one of the pads and remote works like new
Now when I walk to the car I hit lock/unlock 100 times just cause I can.
Order that and your problems will be over!
I had the same problem. Bought the pad and it started working again then a few months later the battery connection came unsoldered. Easy to fix if u have a solder gun. and maybe a little solder but not necessary just will help get a stronger connection.
