level 4 ac dont work
this car has problem after problem!!! idk if its from the wreck or just cuz it was one of the first ss/sc made
but when i turn the knob to 4 the a/c shuts off completly...but all the other levels wrk fine....i just replaced the filter...
so... im burning up
so... im burning up
Very common problem with all cars. Id bet its going to be the blower motor resistor. Its an easy fix. Eventually level 3 wont work, then 2, then 1. Im telling you most likely its the resistor.
Just buy a new A/C Controls, you can get them off of ebay. My Level 3 doesnt work
Here is a link:A/C Controls
I just replaced my second a/c control - they seem to have a life of only (2) two years - also causes the connection for the fan switch to melt -I buy mine on ebay or a junkyard it's very easy to replace just remove the trim pieces and swap out the control units -
my fan speeds are all working but I took out my blower motor resistor to take a look at it - besides being dirty and looking like it got a little wet - (a small rust spot) and streaks - how do I tell if I need to replace this?
1 Post
You don't need to replace it... You could just clean up the connection a bit by using a small brush and some baking soda mixed with water then clean the excess off with a q-tip of isopropyl alcohol.
