LNF Coupe Problem:
LNF Coupe Problem:
I own a LNF coupe, Im having a knock/clicking in the rear end while going over moderate to heavy bumps.
It does NOT do it if the brakes are engaged.
Ive checked my callipers, pads, twist bar bushings, exhaust clearance and shocks.
Any insight?
Any insight?
Its the pads; been there.
Jack up the rear end and rotate the wheels by hand; make it jerk. Watch the pads and you can see them "floating" in the caliper. The steel backingplate moves around and knocks around in the caliper. Shitty design of the Teves calipers. You shoud get new OEM only caliper clips. Bend them tighter and install them. Pads wont move anymore then.
