Lnf timing chain
Old 12-09-2015 | 11:30 PM
T-fog's Avatar
I don't get it I can't post my reply it almost all of it keeps getting deleted ? besides the first 2 lines? I will pm you
Old 12-10-2015 | 02:36 AM
YelloEye's Avatar
Sounds like the chain is a bit loose, you might be missing the lower chain guide bolt if your tensioner is fine. Time to pull off the valve cover and have a looksee.
https://www.cobaltss.net/forums/prob...de-fix-307558/
T-fog (12-10-2015)
Old 12-10-2015 | 02:40 PM
ssTurbocharged's Avatar
Where is that bolt located??
Old 12-10-2015 | 09:35 PM
YelloEye's Avatar
Passenger side of the head right next to the engine hoist point if you have one.
Old 12-10-2015 | 09:37 PM
YelloEye's Avatar
Looks like the black guide in mine died.
Old 12-10-2015 | 10:24 PM
Thanks for that.
So I'm a bit confused. That guide down there breaks because the bolt backs out? And this is supposed to be a fix for that?
Sorry for all the questions
Old 12-10-2015 | 10:36 PM
T-fog's Avatar
Sorry I had to post twice and separate a few things this is the only way I could post without it getting deleted.
Yes you are correct and also the bolt can break too.
I think mongrat
Is the name of a member on here who has a fix if you have a broken bolt. But I would only do this is temporary fix.
Old 12-10-2015 | 10:45 PM
T-fog's Avatar
But like I said it is temporary and would look into this, esp if you need to get in there change a broken guide anyways this will avoid future issues. VV
https://www.cobaltss.net/forums/2-0l...pgrade-298146/
Old 12-10-2015 | 11:30 PM
Update: I changed my tensioner and all went well. At first it sounded the same but I just drove my car again. My noise actually got a lot quieter which is great.
I would want to replace all chains and guides but I'd really rather wait, the car only has 58k and it is stock
Old 12-11-2015 | 02:37 AM
YelloEye's Avatar
Originally Posted by ssTurbocharged
Thanks for that.
The guide breaks because the tensioner isn't doing its job well. The bolt typically breaks because it was over torqued and snaps. There is a good permanent fix for it with the large bolt that mongorat makes now. The other alternative is to get the sheered bolt extracted and put in the ARP bolts which are 12.9 bolts.
Old 12-11-2015 | 12:10 PM
  #36
Omiotek's Avatar
The bolt also breaks from someone not using loctite and reusing the bolt. It eventually backs out
Old 12-11-2015 | 01:43 PM
  #37
YelloEye's Avatar
I'm hoping I can get a set of bolts before Sunday when I'm going to be changing out the guides.
Old 12-11-2015 | 08:46 PM
  #38
T-fog's Avatar
Doesn't mongorats bolt go against the other existing bolt holding it in position? or taking its place if it does break? I have the arp bolts but now I am curious if I should get the bolt mongorat makes and install it for extra safety ? Also If you don't mind explaining or showing me what exactly his bolt does?
Old 12-12-2015 | 01:12 AM
  #39
Update: The tensioner fixed my noise. The car runs a lot better now and has no noises. Anyone with noise there definitely try a new tensioner first
Old 12-12-2015 | 04:53 PM
  #40
T-fog's Avatar
That's good man glad to hear you fixed her.
Also just wanted to say thanks for posting up an end result for future members who may encounter this problem.
Old 12-12-2015 | 08:12 PM
  #41
Exactly my thinking. A lot of threads have no end result. Also big thanks to you and the other guys who helped me out.
Also interested in that bolt
Old 12-14-2015 | 03:14 PM
  #42
YelloEye's Avatar
Can confirm Omiotek is right, there really is a spring in that tensioner. No idea why I doubted you, you've been in this world longer than I have
I ended up replacing my entire timing set except for the sprockets. That guide was messed up.
Old 12-14-2015 | 03:24 PM
  #43
Yeah there's definitely a Spring. Mine came set so I had to take it apart.
Old 12-14-2015 | 03:49 PM
  #44
YelloEye's Avatar
Guess they were rough with your package and the tensioner got excited
Old 12-15-2015 | 10:29 PM
  #45
Omiotek's Avatar
the tensioners ratchet into place. it takes some finaggling to get it into the position to put it in. make sure the recess is lines up with the correct piece on the guide.
Jason Bernal
12-20-2015 12:31 PM
The Rookie24
12-03-2015 08:44 AM
ZxZueSxS
12-02-2015 12:58 AM
09SSlow
Tuning
12-01-2015 04:14 PM
janinexxmariee
11-29-2015 03:58 AM
Quick Reply: Lnf timing chain
