(LNF) Won't start no fuel, have codes.
2 days ago I started the balt and let it warm up before work. Car sat at idle for 10 mins or so I jumped in to go to work the car made it 10 feet if that and I got "reduced engine power" light followed by a CEL. Made it to the bottom of the driveway and it quite running and the oil pressure light came on. Got out and looked it over didn't see anything wrong went to start it again it started but only ran for 30 seconds or so tired a again gave it gas this time and it died the second i touched the pedal. At this point I was late for work so I pushed it out of the way and called for a ride.
Got home tried to start it again and noticed I didn't hear the fuel pump. Pressed the pressure relief valve and had zero pressure in the line. Tonight a buddy came over with a scanner from work to read the stored DTC's (I disconnected the battery and lost the CEL) here is what I found.
P0446
P0499
P062B
P0270
P0204
P062B
P0650
Getting ready to start researching each code but figured I would post here and see what help i could get here first.
P0446
P0499
P062B
P0270
P0204
P062B
P0650
OrangeK
09-19-2016 08:39 AM
CTCOBALTSSS
05-08-2016 04:15 PM
Gelladuga69
06-24-2013 06:01 PM
