Looking for immediate Help!
Got parts in last week and just got chance to install. So far I have installed forge BPV, K&N SRI, and Injen charge pipe. Everything tightened and set to go I turn the key and get a click click click. Then started throwing check lights and I shut car off and unhooked battery... Any recommendations??? 2010 cobalt ss/tc
Clicking is usually a sign of a dead battery. And by check lights do you mean actual codes or just lights on the dash? Because if it's just lights on the dash, it's normal for them to come on until the car is started
No reason for battery to be dead though and had power last night turned over after install of parts. Didn't actually drive though. So I got in it tonight turned key and clicked a few times showed the normal dash lights and this it started with check traction control, check abs, check esc, then I switched it off and unhooked battery. 3 simple bolt-ons just installed followed instructions as well as all the advice found through forms etc etc.
