Low oil pressure?
Low oil pressure?
I am trying to track down a engine noise I have and since everything thats ticking related is going to be oil related im going to start there.
I have a 03 2.2 l61 in my cav. I have a oil pressure sender in the port on the side of my head. If it matters its the back port of the 2.
When cold my oil pressure is 60-80 psi depending on how cold it is out there.
But when its hot in the summer and im idling its almost zero, according to the gauge. As soon as I hit the gas it goes up to about 10 psi, and when driving is about 10-15psi.
Is this normal for this oil sender location?
The noise im getting is not a tensioner noise. (ive changed the tensioner and inspected the timing set for issues) Its about half speed of the motor and only makes noise at about 1300rpm, with a slight tick at idle. The noise gets a little better once its warmed up but its always there for the most part warm or cold.
importkiller
09-30-2015 07:18 PM
