ls 2.2 ENGINE RUNNING HOT
Well, I had to replace my cobalts cat at 80,000 because it was plugged. I also replaced my thermostat and had the coolant system flushed. For some reason my engine temp is mostly around 198-202 degrees. It's cold in illinois now and I'm afraid when it warms up my car is gonna really overheat. The thermostat was rated at 180 degrees so why is this thing heating up??? Also my gas mileage is about 25 miles city/highway. Any ideas???
if you're idling a lot in traffic or what not, yea it will hit upwards of 200-201
my engine seems to run hotter in the winter. lol.
but it normally sits near 189 when moving. never lower and very rarely higher.
now stopped. hell it will hit 210 easy.
i drive around with the coolant temp on my DIC lol
Double check and make sure that there isnt any air bubbles in the system. would be my suggestion because they shouldnt be running that hot. It wont hurt it but that 180 thermostat should be kicking in. I would also check sometime they are bgad out of the box maybe the tstat has failed.
My car sits at 189 while moving and the highest Ive seen was 210
That's why all cars should have a temperature gauge displayed at all times somewhere on the dash. I love gauges.
My car NEVER went above 189 while moving and 210 while stopped in hot weather. I noticed one day that it was running in the 200-220s alot. Then My engine light came on and my gauge gave NO temp reading (said ---). Took it to the dealership and it was the thermastat. had it replaced and im back at 189.
It wouldnt hurt to get it checked. I only have 37K miles on my balt. BTW its coverd under drivetrain warrenty till 65K I think.
I put mine into a curb last year and jacked the radiator and didnt notice because 1 the only damage was to the lower front lip, and 2 there was so much snow on the ground that i woudnt have noticed liquid. I hate to say it i got you beat... 350 plus and blew the gasket and pretty much warped everything else.
Edit: lol yes im dumb, never had a car overheat, and wasnt sure how far i could take it, i made it home, and it started the next day, but not without every color of the "Im sick" rainbow coming out the back.
roth
09-26-2015 12:16 PM
