lsj boost issues
lsj boost issues
so every ounce in awile when I get on it it will try to boost but kinda boogs and doesn't boost other times it boosts fine any ideas?
there are 2 things that control it 1 is the boost bypass solenoid and the boost bypass actuator by correctly doing the boost bypass mod you take the solenoid out of the circuit and then that leaves the boost bypass actuator if you disable the solenoid by removing the vacuum source and you still have a low pressure problem then you either have a bad actuator or cracked vacuum lines or a stuck open butterfly on the blower
then you did it wrong or you got a different problem
