lsj timing
Old 01-29-2014, 03:32 PM
mrbelvedere's Avatar
take it to a shop
Old 01-29-2014, 03:39 PM
josh6854's Avatar
I'm capable of doin this. I've just heard different mark positions and locations. This bottom pulley isn't still clear about where the mark on the cover is. I'm outside on it now.
Old 01-29-2014, 03:41 PM
staged posted a pic of the front cover and where the marks are on it
Old 01-29-2014, 03:49 PM
josh6854's Avatar
So looking at the timing over from the passenger wheel area, the notch is upward to the left?
Old 01-29-2014, 03:53 PM
josh6854's Avatar
Is this the mark its the only thing on the cover I see. I know where the notch on the pulley itself is
Old 01-29-2014, 04:08 PM
look at the pretty picture its at the end of the oil pump relief
Old 01-29-2014, 04:12 PM
josh6854's Avatar
So is it possible for both top gears to be lined up at 10 and 2 with the correct color links and the bottom pulley not?
Old 01-29-2014, 04:24 PM
for the last time use a compression tester screw it in to #4 rotate the engine by hand when it builds compression line the marks up on the front cover and dampener then line the marks up on the cps housing and install
Old 01-29-2014, 10:53 PM
josh6854's Avatar
Did you have to actually remove the timing cover?
Old 01-29-2014, 11:10 PM
no and this is so simple to do if you cant do it with the given information TAKE it to a shop
SmitBag
09-07-2016 08:05 AM
Shanman
ZZ Performance
43
08-26-2016 08:43 PM
Spanky's Monkey
03-07-2016 06:06 PM
yellowsupercharged06
09-17-2015 04:40 PM
matthewwalsh1994@gma
09-10-2015 10:48 AM
Quick Reply: lsj timing
