My car is shaking please help!
Old 11-11-2015 | 10:20 AM
Corrinaannajo's Avatar
I drive a 2006 Chevy cobalt SS I just got all four brakes and rotors replaced and the swaybar links replaced and my car still shakes when I'm going down the road. It starts shaking at 45 MPH and stops around 60 MPH. It shakes even more when I am at those speeds and try to slow down. It doesn't do it as bad when I hit my brakes slightly harder to slow down. I do know I was told I need new caliper brackets on both sides in front. Any ideas what's wrong?
Old 11-11-2015 | 11:05 AM
jcobaltss's Avatar
Did you check your axles?
Old 11-11-2015 | 12:05 PM
cluelessk's Avatar
Sounds like you got a shop to do the work?
Take it back.
Old 11-11-2015 | 12:44 PM
You think I need new axles all together?
Old 11-11-2015 | 12:52 PM
cluelessk's Avatar
Could be axles, wheel bearings, could even be tires
Old 11-11-2015 | 01:21 PM
turboecotec02's Avatar
I know there's alot of things that can make your car shake but mine shook at exactly those speeds. I never would have thought this but my struts where completely toast. Replaced those and it doesn't shake 1 bit now. I don't know why blown struts would make it shake but in my case that's exactly what it was. Good luck
Corrinaannajo (11-17-2015)
Old 11-11-2015 | 01:22 PM
JapEatr's Avatar
South Central *********
wheel bearings
Old 11-12-2015 | 03:19 PM
tomj77's Avatar
Clean the dirt out of ur rear rims.
Old 11-14-2015 | 02:32 PM
Something happened
Today I was going down the road and had to turn around and when I pulled into a place and turned around when I got back on the road my car was shaking almost no matter what speed I went and I had to drive like 25 the whole way home I think something broke even more.
Old 11-14-2015 | 05:26 PM
SR Tech's Avatar
One of the wheels not tight after brake replacement?
Old 11-16-2015 | 12:23 PM
Could it be that I need a front end alignment after having my sway bar links were replaced?
Old 11-16-2015 | 12:25 PM
That would help for sure
Old 11-17-2015 | 11:06 AM
I took it in and they said I need ball joints, struts, and calipers. Thanks everyone that threw out suggestions that's why I love this website.
Old 11-21-2015 | 10:54 PM
Jacque8080's Avatar
Did it get fixed?
MP81
10-27-2023 03:10 PM
drewSSyboy
12-16-2015 04:00 PM
SpeedyGonzalez
11-11-2015 06:38 PM
firehawk618
11-11-2015 01:52 PM
sheape
11-09-2015 11:42 AM
Quick Reply: My car is shaking please help!
