My car wont move =[
My car wont move =[
My car wont turn on, when i try to turn it on, it makes on click from under the hood and thats it. The lights on the dash get kind of dim and the door chime doesnt sound right, and thats with the key all of the way forward in i guess the start position. The battery isnt dead. And i tried to push start it, but when i release the clutch my car stops and jerks like i slammed on the breaks. Any ideas with whats wrong with it?
Battery for sure. If you turn on your headlights or other accessory my guess is they will be very dim or wipers won't move. You are describing a classic dead battery symptom.
You cannot push start the car becuase it requires electricity to run the computer, gas pump, etc etc.
Get a jump start or replace the battery.
I got my car to turn on this morning. I push started it in reverse, but i had to start the car and then pop the clutch, and that got it going. but it idles pretty bad. (not the battery) when it idles the needle jumps from 300-400rpm up to 1500-1600rpm, like it cant find the right spot. what could cause my car to have such a bad idle and possibly cause my car not to start.
Always jump start in second gear never first the gear ratio is to low and reverse is worse !
Would of been easier to just boost it with another car.
As for your idle problem if it idled fine before this ,plugs could be fouled take it for a good run or clean the plugs manually.
Could have a bad vac leak as well.
Nothing that I can think of woul make my engine seize up like it did, I park my car, woke up and it wouldn't start or move in gear. Also, I was doing the push start in reverse because I was on a hill facing the wrong direction. I live on a narrow street and doing a 7 point turn by myself in 100 degree weather isn't easy.
Make sure your battery connections are tight and not loose.
Also,
Check where the ground one hooks to the ground next to the battery make sure thats not loose either.
Loose battery connections will emmulate a dead battery
Try this for your erratic Idle
https://www.cobaltss.net/forums/2-0l...inally-116051/
Also,
Adam144
09-03-2015 07:48 PM
