mysterious wobble
mysterious wobble
So my car shakes under throttle, doesnt matter the RPM, but load does matter. Cruising no shaking and braking doesn't either. WOT does and say anything above 50% throttle. It's not consistent and much worse in 2nd vs any other gear. Other times at WOT it's fine. Did the usual jack up and shake, no play except a little side to side movement with the driver wheel. The drivers wheel makes a constant clicking sound when I spin it and the passenger is silent.
I'm thinking it's bad cv's, any other thoughts?
yup bad cv joint brudda. cv boot looks ok? no rips or leaks? if you load and unload the suspension kinda quickly youlll hear air escape from the cv boot. it doesn't always have to be losing grease to fail though. you lowered?
ps. Send me your number again son!!
a lot of times people will over extend the cv joint while doing struts or control arms hubs etc, drop it down on the ground when theyre done and destroy ****. if the part is in normal operating conditions it shouldn't fail. most stuff like this is caused by other parts failing/people not installing or handling the parts correctly.
Im having the same problem
Things Ive thought could be the cause:
* wheel bearing
* outter tie rod
* CV joint
* ball joint
* control arm bushings <---pretty sure these are not the cause.
* Int shaft bearing
* axles
These have been ruled out: \/ ...On my winter rims and tires I still have the same problems.
* Tire balance
* Bad tire
* bent rim
[SIZE="4"]I started a thread in the suspension section...maybe we'll get more view.[SIZE]
https://www.cobaltss.net/forums/suspension-67/steering-wheel-wobble-lets-solve-damn-problem-217708/
* wheel bearing
* outter tie rod
* CV joint
* ball joint
* Int shaft bearing
* axles
* Tire balance
* Bad tire
* bent rim
