Need to dry the passenger side
Old 06-29-2016 | 03:04 PM
katriik's Avatar
So recently I found out that the driver side has water under the carpet.
I removed some panels, raised the carpet to find out that the under side was wet, not soaked.
However, the panel that is under it, behind the pedals, (aka the noise barrier i think), its foam is soaked.
Can't tell where the water is coming from (the sunroof drain is working and clean. It ends right inside a hole next to the hood open lever.
I would like to check with you guys if you know if someone knows how to remove the noise barrier that is behind the pedals.
That way I can dry it out and do a more in-depth investigation.
Thanks.
onlyjosh
11-02-2016 07:55 PM
katriik
06-29-2016 08:55 PM
Gankzulu
06-27-2016 09:17 PM
johvans
06-24-2016 03:13 PM
Dougsterbob
06-22-2016 02:39 PM
