Need help P2135, P2176, P0121
Old 08-08-2011, 08:18 PM
redcobalt07's Avatar
$500 to replace a throttle body? What a rip off
Old 08-08-2011, 08:22 PM
G_Pelly's Avatar
yah just under 500 from the dealer
Old 08-08-2011, 08:23 PM
Tundraboarder666's Avatar
Wow. you can get them off GMPD for a lot cheaper
Old 08-11-2011, 04:32 PM
tpete763's Avatar
Update: Got a call from the dealer today and they said that the connector to the throttle body was broken (looked fine to me and them the last 2 times they had it though?) They said when I had my oil pump replaced and engine rebuilt under warranty 3 years ago that the tech working on my car must have broken it when he was reassembling the motor. Is this believable to anyone that the connector was good for 2.5 years after they did the engine work and now just started acting up like this?
Also the engine work was done at a Chevy dealer in Pennsylvania, isn't their work on the car guaranteed while I still own the car? Should the dealer be covering the cost of this since they said it must have been broken when the dealer did the warranty work?
Old 08-11-2011, 05:51 PM
If he brief it then they should fix it for free.
Old 08-11-2011, 08:24 PM
tpete763's Avatar
A different dealership did the work though. Does that make a difference?
Old 08-11-2011, 09:39 PM
I wouldn't think it would matter just like returning something to target.
Old 08-12-2011, 01:58 PM
tpete763's Avatar
I just called my extended warranty company to see why they denied the claim to get the wiring to my throttle body fixed and guess what. they told me that the DEALERSHIP NEVER CALLED TO FILE A CLAIM FOR IT!!!! (they keep everything in the computer, even when I called them they logged it) They told me the last contact they had from the dealer was on august 2nd when they replaced the battery and the gas pedal and nothing since then.
So I just called the dealership and talked to the service manager. He said he would call back in about an hour.
Old 08-12-2011, 03:14 PM
Awesome. Well hopefully it will be resolved then when they call them and tell them about it.
Old 08-15-2011, 09:51 PM
tpete763's Avatar
Update: Dealership called today and they replaced the harness to the throttle body, the service adviser told me that the new TB harness did not fix the problem and they were still running more tests to figure out whats wrong, he said that they will probably have to replace more wiring still but they are not sure of which wires yet.
Old 08-15-2011, 09:57 PM
  #36
G_Pelly's Avatar
my car went into reduced power mode again yesterday
Old 08-15-2011, 10:22 PM
  #37
tpete763's Avatar
So far they've replaced a lot of parts on my car (throttle body, TB wiring harness, gas pedal, & battery), and still haven't been able to figure out why my car is doing this. They've had it since last Monday too, I've been car-less since then.
Old 08-16-2011, 09:23 PM
  #38
tpete763's Avatar
Update: I got my car back today and everything is running normal again for now. Hopefully this time the fix is for good! They replaced the TB connector, some of the wires going to the computer from the TB, Wires going from the gas pedal to the computer, and the computer itself. I'm guessing the computer took a crap on me because they replaced the wiring and said it still didn't fix the codes. I got it back today with a new computer and whatever work they did with the wires they replaced.
Old 08-16-2011, 09:31 PM
  #39
Coblasts's Avatar
Hopefully they didnt hack up the wires to bad,Hows it look?
Old 08-16-2011, 11:02 PM
  #40
tpete763's Avatar
they didn't really hack up the wires too much, they did a pretty clean install with everything. It looks messy because they just didn't put the wire loom back around the majority of the wires they took it off of. So looks like my next project will be re-wrapping the wires in a new loom to clean up the look and protect the new wires.
New TB wiring:
Wiring to the right of the engine (what they didn't wrap back up):
Shiny new computer:
Please excuse the dirty engine bay (and upside down pic of engine bay) lol
Old 01-06-2014, 06:54 AM
  #41
ferrucci86's Avatar
I had an issue with my car idleing high then low and high and low for a little while, cleaned my throttle body and it went away. I just got the eng reduce pwr on my DIC went away after i let it run then turned it off twice, that was about 2-3 days ago. No issues since then, hopefully it stays that way.
Old 12-18-2014, 08:36 AM
  #42
blueLNFftw's Avatar
So the PCM went bad then?
Old 12-22-2014, 04:14 AM
  #43
G_Pelly's Avatar
on mine i ended up fixing it by replacing the wire plug that plugs into the throttle body, i just cut the wires and spliced a new one in and never had a problem since
Old 12-22-2014, 08:27 AM
  #44
blueLNFftw's Avatar
Where did you get the new plug?
Dustonian131
09-23-2015 08:03 PM
rukkee
07-09-2010 05:55 PM
rukkee
09-21-2009 06:47 PM
thatotherguy
05-02-2009 09:54 PM
MadboostSS
04-26-2009 07:03 PM
Quick Reply: Need help P2135, P2176, P0121
