need help please!
need help please!
ok so i was drive my car tonight and everything was fine. i shut my car off for about 15mins...then i start it back up and i dont have power steering, windshield wipers, and my airbag light is on. i know it is a fuse i know what on i put a new on in and it keeps blowing does anyone know why or how to fix it. it would help me greatly thanks
yup, if you're blowing the fuse.....a wire is shorting to ground, need to find out which circuit it is and repair the wire.
Do you have any aftermarket electircal things on the car??/ Lights, gauges, etc.?
You didn't say what fuse it was but I found this preliminary info bulletin.
#PIC4578A: EPS/STR Wheel Control Fuse (19#) Open - keywords cntrl EPS fuse19 inop inoperative int power stg steering system whl - (Aug 23, 2007)
Subject: EPS/STR Wheel Control Fuse (#19) Open
Models: 2005-2008 Chevrolet Cobalt
2006-2008 Chevrolet HHR
2005-2006 Pontiac Pursuit (Canada Only)
2007-2008 Pontiac G5
This PI was superseded to add second area for inspection, and add 2008 Model years. Please discard PIC4578.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A customer might complain that their power steering system is in "Default mode" and/or their Steering Wheel Radio Controls are inoperative. A condition has been identified through TAC cases that there is a common area for a wiring Short To Ground (STG) that could cause the EPS/STR Wheel control fuse to open.
Recommendation/Instructions:
There are two locations for wiring concerns:
First check for a STG in circuit # 1539 (PNK) wire behind the radio. This circuit has reportedly been shorted on the radio mounting bracket, and just below the radio bracket almost to the BCM mounting location.
Note: For ease of locating this STG remove the radio, HVAC control head, and the upper console trim panels and inspect for wiring/brace contact.
Second check for a STG in circuit # 339 (PNK) wire behind the drivers side air bag.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
Condition/Concern:
