Need Help Please Anyone
So I think I have a clogged cat. Been running ruff the last couple of days. Engine light on, exhaust doesn't sound right. Problem is today it sounds like there is no exhaust at all. Hard to stay running etc. Is the cat clogged completely and possible blown flex pipe? Any help would be great.. thanks in advance. 2006 Cobalt ss 2.0 supercharged!! Forgot the car was overboosting also!!
Will a modded airbox hurt the warranty? Will they charge me if for some reason the warranty wont fix it? 94,000 miles.. thanks man for the reply
Thanks for your help I just called them. I will take it over the weekend and they will look at it Monday.. Appreciate your help. Thanks a lot
****, op if they want to charge you for it, pm me. I've got a stock lsj downpipe with 300miles on it I'll sell you for much less than a dealer. I bought it from a friend for my old base model, but I bought an LNF instead of boosting the base
So the dealership called me stating that the cat is fine.. They said that they drove it around to see what it was doing and it all checked out.. but there was seven different codes.. one is the cam sensor said the timing chain was hitting the front cover.. and the other was intake and ecm reset.. The last one was for a thermostat swap.. roughly 1700.00 dollars... my question is why the overboosting, lack of power.. and my exhaust sounds it was tore off? Thanks guys
Ok guys have the codes-- p0017, p0833, p0442, p0341, p0300, p0171, and p0128. They state timing chain is loose causing camshaft crankshaft correlation codes.. needs replaced 955.00 Intake gasket UPDATE and ecm reprogram 525.00, thermostat and spark plugs 180.00.
P0341 WAS CHANGED DURING THE SUMMER BY MEAN AND MY FRIEND.
TAKE INTO CONSIDERATION THERE IS A HOLE IN EXHAUST SOMEWHERE THAT JUST HAPPENED ITS LOUD SO IT MIGHT NOT HELP WITH THE CODES. WHERE SHOULD I BEGAN?
if you would have posted in the correct section which is located here Problems/Service/Maintenance - Cobalt SS Network then you would have found this https://www.cobaltss.net/forums/prob...-merged-12015/ which that could have helped you and others help you by posting this
P0017 Crankshaft Position (CKP) - Exhaust Camshaft Position (CMP) Correlation - ECM, PCM
P0833 Clutch Pedal Switch 2 Circuit -PCM
P0442 Evaporative Emission (EVAP) System Small Leak Detected -ECM, PCM
P0341 Camshaft Position (CMP) Sensor Performance -PCM
P0300 Engine Misfire Detected -PCM
P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating -PCM
P0171 Fuel Trim System Lean -PCM
you may have caused the p0017 by pulling the cps housing of the head and not retiming upon reinstallation so if that is the case here is how you fix it
if that doesn't fixit then the engine is out of time and will need retimed so I would just go ahead and replace the chain and then that should take care of both 17/341 codes the evap could be gas cap the 171 could be a vacuum leak the rest should be self explanatory
Ohh gotcha.. sorry! Yes me and my friend changed it boy it was a pain.. One more thing the Chevy dealer said he thought the timing chain was hitting the cover causing the code.. is that possible? Thanks you have been great man!!
