New MAP sensor, but still throwing P1182..? Not sure what else to do..
Ok so I replaced the MAP sensor by injector #1, I also replaced both MAP pressure sensor for the SC. I still get the P1182 (Supercharger Inlet Pressure Sensor Performance HISTORY MIL) I also seen on the scanner that it said my MAP was at 28.9 HG? Not sure what that means but maybe one of you guys know.. I am desperate for help now man I jsut dont understand this car at all.. Please help me out thanks.
I ran the car yesterday, and sprayed all over and did not see any bobbles coming from any where. I di replace the vaccum lines for the bypass/actuator valve but the store I got them from didnt have actual vaccum hose lines so I got rubber fuel injector line, and clamps and put those on.. Think those lines might be causing me issue? the one wasnt long enough either so I had to put a duel plastic male end to connect to of the lines.. I figured as long as the suction wasn't colapsing the lines I should be good..
