Notorious Engine Rattle.
Old 11-04-2013, 08:50 AM
K.Nife's Avatar
All right, now I've done plenty of reading on here about that rattle in the engine some of us get. My rattle can usually only be heard with the radio off and windows up. I rev the engine and rattle goes away. I'd like to know how to tell if it's the coupler or the timing chain tensioner, if it's even that because when I pop the hood, sometimes the rattle doesn't even seem to come from the engine at all. What could this be?
Old 11-04-2013, 09:27 AM
05g5's Avatar
Open the hood
And have a friend or your remote starter start the car a few times till it happens again
Pinpoint the best you can to were its comming from.
If itz the timig chain tensionet hold a long screw driver to the side of the motor( and press to your ear ) a few inchs above whete the water pump is. Should find a lip or spmething to rest it on and listen. Gunna have to get a friend to start the car a few times till the noise happens again. If you can hear clack clack clack its probably the tensioner. Easy job . Will cause major problems if it lets go.. So get er done
The tensioner its self if your standing infront of your motor is on the left hand side right behind the valve cover. Its a 3/4 bolt iirc that just goes into the motor. Easy to find
Old 11-04-2013, 09:29 AM
05g5's Avatar
And mine didnt rattle on every start up. It would happen at random. And only last a few seconds .
Old 11-04-2013, 09:38 AM
K.Nife's Avatar
Got ya. Very thank you for the advise. Sounds like it will be easy to find out if it is the tensioner. I hope that it is because I know it be a pretty cheap and easy fix. Now, how do I find out if it's the coupler?
Old 11-04-2013, 12:14 PM
dolanss06's Avatar
its your timing chains
Old 11-04-2013, 02:43 PM
K.Nife's Avatar
You sound very confident in that.
Old 11-04-2013, 04:02 PM
LotusRenaultF1's Avatar
Cracked
Heads
Every
Valve
Rattles
Oil
Leaks
Engine
Ticks
Old 11-04-2013, 07:54 PM
05g5's Avatar
this is not my car, was pullled off google
but this is where it will be, here in canada i got charged $75 for the bolt ( timing chain tensioner )
right below the arrow
Old 11-05-2013, 06:09 AM
BlackyK's Avatar
The TCT (bolt) head is the same size as the oil filter cap ... 1 1/4 or ~31mm ish.
Old 11-05-2013, 12:01 PM
K.Nife's Avatar
Originally Posted by 05g5
this is not my car, was pullled off google but this is where it will be, here in canada i got charged $75 for the bolt ( timing chain tensioner ) right below the arrow
Would you recommend doing it myself? I've seem threads about how you need to tie the chain so it doesn't jump. And how you need to set the new tensioner. Or should I just take it in and get it fixed since I've never really done engine work besides usual maintenance?
Old 11-05-2013, 01:46 PM
05g5's Avatar
Most say you dont need to do anything other thN take the old one out and put new one in and torque to 75ft lbs iirc
I however played it safe and took my valve cover off and uses like 6 zip ties and strapped te chain in its place than did the tensioner
If it takes you longer than 1.5 hours your doing it wronf. Super easy job . Like 2/10 for difficulty
Old 11-05-2013, 01:52 PM
K.Nife's Avatar
Most say you dont need to do anything other thN take the old one out and put new one in and torque to 75ft lbs iirc I however played it safe and took my valve cover off and uses like 6 zip ties and strapped te chain in its place than did the tensioner If it takes you longer than 1.5 hours your doing it wronf. Super easy job . Like 2/10 for difficulty
Right right I've read threads saying you don't need to set the tensioner. Others saying you do. Some say no ties are needed. Some say you NEED to tie the chain. So basically all I need is the right sized socket and torque wrench?
Old 11-05-2013, 02:38 PM
05g5's Avatar
Yes
I would recomed , personally take the 15 min to pull the valve cover and zip tie that chain, if it for what ever reason ratchets out . you got a few hour job, instead of taking 30 min to avoid it.
My chain didnt move, but i had the zip ties incase it did. And the tensioner should some in the conpressed state. There is info on google how to check and set it
Old 11-05-2013, 03:00 PM
ThexGovenor's Avatar
you have to activate the tensioner with a long screw driver after you put it in. If you dont know you what you are doing I wouldnt recommend it. Just my $.02 how many miles?
Old 11-05-2013, 03:15 PM
K.Nife's Avatar
I'll definitely not take a chance and tie that chain down then. Don't want anything else messing up.
How exactly do I activate it? And I've decided to do all minor work on my ride. This doesn't seem like a big job. My SS has fifty eight thousand on it right now.
Old 11-05-2013, 06:38 PM
not exactly sure. someone might be able to chime in. Just make sure you do that or you will jump a link.
Old 11-05-2013, 07:17 PM
05g5's Avatar
The new style tensioners dont need to be activated. Plug and play basically.
Cuz j never herd of "activating it" till now, and i did mine months ago and its fine - i never activated mine lol so i had to google it to make sure
Old 11-05-2013, 09:25 PM
K.Nife's Avatar
Looks like all I need to do is get a torque wrench and right sized bolt and I'm good to go. Hopefully it's just plug and play. Don't want to find out the hard way if it isn't.
Old 11-05-2013, 10:38 PM
Drunkship's Avatar
I just ordered the revised tensioner today myself. According to Powell Race Part the revised tensioner ACDelco 12608580 is plug and play.
Old 11-05-2013, 11:51 PM
K.Nife's Avatar
Where did you get the part from? I was thinking crateenginedepot.com.
Old 11-05-2013, 11:56 PM
buildmeanempire's Avatar
I got mine from gmpartsdirect. I think I paid about $36 after shipping. Can't remember exactly how much buy it was cheaper than anyone else.
Old 11-06-2013, 12:14 AM
K.Nife's Avatar
And this is the revised tensioner, yes?
Old 11-06-2013, 12:16 AM
Sure is but like I said it may not be $36 but it WAS the cheapest one I found.
Old 11-06-2013, 12:18 AM
K.Nife's Avatar
I'll take a look. Thanks everyone for the input. Obliged.
Old 11-06-2013, 12:16 PM
Drunkship's Avatar
I got mine on Amazon for $32 + shipping. ACDelco 12608580 Timing Chain Tensioner Assembly
Quick Reply: Notorious Engine Rattle.
