OBD-2 Port No Workie! Please Help!
Old 02-27-2007 | 11:20 PM
2K5SS/SC?'s Avatar
Well, I've cleared codes etc many times with a handheld OBD-2 reader. I went to hook up with my HPTuners for the first time tonight and it said the vehicle had no power, so used the HPTuners trouble shooting guide and still nothing. I tried my OBD-2 code scanner/clearer and that wouldn't work either! No power or anything like normal!
Did I blow a fuse or what? The OBD-2 Port will not produce power to run either device, but the car runs fine.
Old 02-27-2007 | 11:29 PM
jeremie's Avatar
yeah check your fuses. i think its the cigar lighter fuse
cobaltBlackss's Avatar
this has happened to me before. It may be the device drivers, you should ask the help on the hptuners website about your situation.
Old 02-27-2007 | 11:32 PM
2K5SS/SC?'s Avatar
Thank you very much man! I was freaking out for a few mintues until I realized it. Now, where is that fuze panel? Is it the passenger side center console one or the under the hood one? Thanks again!
It can't be the device drivers because my code clearer won't even work. It doesn't even receive power like it normally does! Thanks for the suggestion though!
Old 02-28-2007 | 12:08 AM
jeremie's Avatar
im pretty sure its the one down on the passanger side console area. if its not there its under the hood lol
Old 02-28-2007 | 10:07 AM
hmmm....I can't think of anything else than a fuse or the actual wiring of the port. hope you figure it out. This should be something covered by warranty if you can't figure it out
Old 02-28-2007 | 10:37 AM
06blackg85ss's Avatar
not the first time I heard of this... 99% of the time its just a fuse
Old 02-28-2007 | 11:16 AM
Doc's Avatar
Doc
^^ its a fuse, which one, I don't remember....
Old 02-28-2007 | 11:21 AM
Pyros777's Avatar
https://www.cobaltss.net/forums/problems-service-maintenance-69/obd-ii-fuse-44071/#post763842
Originally Posted by hardtocope
is in the fuse panel on the passenger side, just look at the diagram it will say diagnostic ecm fuse.
Old 02-28-2007 | 12:02 PM
NightriderCobaltSS's Avatar
Actually No its not the ECM fuse look under the hood fuse box for cig lighter that is the one. i am 100% sure
Old 02-28-2007 | 05:19 PM
2K5SS/SC?'s Avatar
Found it! It is indeed under the hood, and it's the 15amp fuse that is to the passenger side of the box labeled "LTR." Now to play with HPTuners when I get home!
05-28-2022 04:47 AM
01-12-2016 01:01 AM
10-13-2015 10:32 PM
goaliemo
09-28-2015 02:37 PM
09-27-2015 09:53 PM
Quick Reply: OBD-2 Port No Workie! Please Help!
