OBD2 codes coming up none stop!!! also have a magically missing sensor...
hello i have a 2006 supercharged 2.0 lsj vin p to be exact and i need some help identifying a missing sensor, as well as advice on which sensors to replace that will most likely stop all the issues considering ive heard replacing one or two sensors will erase all the codes coming up, ive already replaced the Baro sensor and that didnt fix the baro sensor code so im gonna next go with the maf sensor. heres the codes and pictures of the missing sensor...
P0069
P0098
P0480
P2228
P1182
i was also given the knock sensor code but ive heard that can pop up if the car has been sitting a while and has old gas and because i just got the engine swapped, yes the car as sitting for a little over 2 months.
and this is the missing sensor. it right under the fuse box
P0069
P0098
P0480
P2228
P1182
Fearedbynone
04-20-2016 11:12 PM
