odd OBD2 code
odd OBD2 code
2004 Saturn Ion 2 Quad Coupe
My parking brake light is constantly on, so I hooked up my laptop hoping I could find a code. I did, but can't find info on it anywhere. The most I was able to find is that it's a GM-specific code.
Code: B2AAA
Anyone have any clue what this code means? I can't find info on it anywhere.
Screencap:
Code: B2AAA
Screencap:
What scan gauage are you using?
I came across this:
I came across this:
"A module in your vehicle is reporting a code that doesn't make any sense (B2AAA) because it is overwriting the true code and that B2AAA codes is the first code the SG2 is picking up. You can send a command to the ScanGaugeII in order to read the raw data. To do this:
From the home screen select MORE> MORE> CMNDS > choose a memory slot> EDIT> enter the numbers 03> SEND.
It's a ProScan kit for my laptop.
OBD-II (OBD2) Scan Tool Software and Hardware - ProScan
The brake light has been on since I had my transmission and clutch replaced so I'm assuming it's a random disconnected brake sensor.
OrangeCoba
09-25-2015 06:06 PM
