Oil Pressure Light Flicker
Old 07-01-2016 | 05:18 PM
bigez96's Avatar
So, about a week ago, I started having this small issue where the oil pressure light would come on for a second, just long enough for you to notice it, the car would chime, and it would go out. This was happening about once a day. Now it's happening almost every time I drive the car. If I run to the store, it'll go on once or twice on the way there, and once or twice on the way home. I never get any sort of message on the DIC. The oil level itself is good. Is this just a small electrical issue like a loose wire or bad sensor, or is this something I need to worry about?
Old 07-01-2016 | 06:40 PM
bigez96's Avatar
Sorry, I forgot to talk about the car! It's a 2005 Cobalt Base with just under 160,000 miles. It is running a synthetic oil blend.
Old 07-02-2016 | 12:08 AM
Sl0wbaltSS's Avatar
RIP engine.
Check the oil pressure though and the sensor.
Old 07-02-2016 | 12:23 AM
bigez96's Avatar
Update: After watching when the light was coming on, I have figured out that it comes on when turning, and when the clutch is engaged. Not every time, but that's when it happens.
Old 07-02-2016 | 07:12 AM
turboecotec02's Avatar
Sounds to me with 160 on the clock the pump may be dieing. I would definitely get it checked out unless you want to replace your engine. If you are handy with tools you might could install some kind of oil pressure gauge to verify it is having oil pressure problems. Just my guess
Ryans09SS
06-10-2024 12:09 AM
05RLS2
01-18-2023 03:32 AM
chuckie
04-18-2018 03:45 AM
Hollifield21
05-05-2016 10:14 PM
Jamie Craig
04-12-2016 07:03 PM
Quick Reply: Oil Pressure Light Flicker
