Overheating Problem
Old 12-25-2013, 12:05 AM
05g5's Avatar
When standing infront of the car:
The water pump is on the left hand side of the motor
And the tstat is on the right hand side right behind the exhaust manifold
There is a odd shape aluminum tubw that connects the water pump to the tstat and tstat housing.
Inside that housing ( right hand side of the motor ) goes ** in order of removal ** first the black sleve- which has grooves and a cut out for coolant to flow into the heater core, then the thermostat.
When putting it back tpgether, the thermostat goes in first, then the black sleve.
Align that ****** up, hold the O ring inplace and connect the aluminum tube. You will know what im talking about once you are in there.
These tstats, as far as i know, the ss/tc is different, the thermostats can in fact fit in two different ways. But the correct way is tstat first then te black sleeve . Tstat then black sleve will fit but not flow coolant
Old 12-25-2013, 12:30 AM
BlackielawlessSS's Avatar
How many miles are on your car?
Old 12-25-2013, 09:22 AM
Powell Race Parts's Avatar
what t stat black sleeve? This thread is sadly funny. Air lock, fix it. water pump check it. merry xmas
Old 12-25-2013, 01:39 PM
droponikz's Avatar
ok then thermostat on right side water pump on the right...iv had the thermostat and its housing on and off 3 times already...maybe because I'm ot getting all the hoses off or somethin I am clueless as to what the black sleeve is..is it actually inside the housing? dam near all the work has to be done from the top am I right?...these notches you are talkin about...are they on the upper or lower thermostat housing?...and mine is an sc...so I'm wonderin if some things are a little different ...sorry if this is becoming monogomous but I really need this issue solved.
Old 12-25-2013, 01:56 PM
Lame9910's Avatar
Listen to powell. It's either air locked or your pump is not working.
Old 12-25-2013, 03:16 PM
droponikz's Avatar
90k
Old 12-25-2013, 04:01 PM
droponikz's Avatar
Yes I see no black sleeve...there are black hoses...and a black o ring that fits on top the tstat...from under there I see the water pump feedline from the pump to the bottom housing of the tstat..then put the thermostat with the spring up into the top housing?...
Old 12-25-2013, 04:15 PM
two black o rings. one inside the t stat you cant access easily and should leave alone and one is already fitted to the outside of the t stat upper plate. it fits spring down into the cavity, the t stat housing goes on top, two 6 x1 mm bolts torqued to 89 INCH pounds.
Old 12-25-2013, 06:22 PM
droponikz's Avatar
Ok...so spring side down...gotcha...all the pictures iv seen were sideways...n its hard to see anything back there so I was havin some trouble..also I have 3 10 mm bolts for my top housing...
Old 12-25-2013, 06:34 PM
is it a 2.2? same torque spec. 3 bolts. lol
Old 12-25-2013, 06:59 PM
  #36
droponikz's Avatar
2.0..alright...ill check if the pump is workin properly tomorrow then
Old 12-26-2013, 03:06 PM
  #37
droponikz's Avatar
Ok thermostat is in spring side down haha...from what I seen from the little access panel on the side...the pump is spinning and working...my vents seem to be wantin to warm...had her up at around 2500 rpms letting the bubbles escape...she still wants to run hot though...any ideas...I bought a radiator from parts geek...like 84 bucks..wonderin if its ****?
Old 12-26-2013, 03:50 PM
  #38
droponikz's Avatar
Originally Posted by Sunburst_SS
if you take off the little access panel on the timing cover....you will be able to see the water pump gear. Take the cover off (4 bolts) then run the car and see if the pump is turning.
are you sure you got all the air out of the system?
Did this...everything was turning...but when I started it with the drain plug out...coolant wasn't coming out with any force ..
Old 12-26-2013, 04:08 PM
  #39
In the L.61 2.2 thermostat mounting is horizontal and 2.0 the housing is roughly vertical. the 2.2 has an orientation the t state with the bulb cradle vertically positioned; the 2.0 does not have an orientation specified; both the thermostat housings 2.2 and 2.0 are secured with two bolts.
You must fill from the top hose; until the hose is full and you will spill a little pushing it onto the head nipple. so be it.
this is the 2.2. check the orientation
2.0
Old 12-26-2013, 06:54 PM
  #40
droponikz's Avatar
Ok talked to a mechanic n he believes its an air lock in the heater core...so he told me to remove the heater core lines and let them drain...he said be careful with the plastic clips...but the only ones I see on the heater core lines are metal...does anyone have any feedback about this proposition?
Old 12-26-2013, 07:12 PM
  #41
not the heater core with an air lock. really.
internet diagnosis sucks.
check for blockage in the rad core; hoses kinked large and small; pressure test system. etc etc fill it properly by the book.
Old 12-26-2013, 09:44 PM
  #42
Lame9910's Avatar
Just start over and fill from hose like powell said.
Old 12-27-2013, 03:18 PM
  #43
kzak104's Avatar
I've filled the cooling system through the resivoir a few times with no problems. And our heater cores have aluminum dinks with rubber hose clamped onto them. Probably not an air lock in the heater core tho. Do u have heat?
turbochargedss2012
09-20-2023 12:17 PM
yellow dragon
09-28-2015 09:49 PM
Iceberg
09-28-2015 01:31 PM
DocSvensk
09-27-2015 02:24 PM
Adiaz1ss
09-26-2015 11:51 PM
Quick Reply: Overheating Problem
