P0107 - Map Dtc
P0107 - Map Dtc
This is the code that keeps coming up when I scan with HPTuners.
P0107 - Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage (SES) (Pending) (Old) (History) (Current) (Immature)
I also noticed that it doesn't log the MAP in the scanner either.
This car had the Rev-it-up kit on it and we recently removed it. Actually, snipped the wires.
Has anyone experienced this DTC before?
If you have, whats the fix?
Thanks
Thanks
