P0204
that's your cylinder #4 injector, maybe it got stuck? if it happens again you know something is wrong with that injector, but your CEL pops on the second fault so there was 2 instances.
Yeah,it only came on once and then it never came back,i had the injectors cleaned but i think they are faulty and the thing is,these injectors have only 600miles on them
maybe clean the injectors, if you happen to pull off the rail check if the seals are still intact and not floating around. sometimes CEL pop on once in a lifetime and your just like 'wtf?' delete it and you never see it again.
Once i cleared them they never came back but the cars rpm's are all over the place at idle,have a friends set of brand new injectors that he said i could try so that i can eliminate the injectors if thats the problem.
The injector control circuit goes all the way back into the PCM. Can't rule out the fact that the PCM may be the culprit, especially after all the stuff you've changed.
Do you have any LSJ friends that would let you borrow their PCM + flash it with your HP Tune?
So I'm getting this code too ... I've switched injectors around and everything was fine for a week but then it started popping up again... I did notice that the hard seal around injector #4 was a little loose... I cleaned it on that same day but code popped up again... I'm waiting for other injectors and harness to arrive
turbosmart4
04-18-2015 06:21 PM
