P0433 & p2229
P0433 & p2229
I've been getting P0433 and P2229 and I can't figure it out. I've replaced my map sensor and still get the CEL and stumbling at idle. The car acts fine at WOT.
For the baro code check your wires and connector on it (Barometer sensor)could of been damaged some how.(Its between the SC and the rocker cover )
The other code is your evap cannister purge solenoid so I dont know why you thought changing the maf sensor would help ?
The baro and the evap purge valve are roughly located in the same area,you might have a pinched wire there somewhere or one rubbed through and is shorting take a good look and follow the wires back from the purge valve and the baro to the pcm and look carefully.
The baro and the evap purge valve are roughly located in the same area,you might have a pinched wire there somewhere or onr rubbed through and is shorting take a good look and follow the wires back from the purge valve and the baro to the pcm and look carefully.
