P0443
Update!!
Took the balt to GM Was a blowen fuse causeing my problem I figured ehh simple fix. They told me its MY fault, Because, I had halo headlights. YES SIR... Halos that are tapped into my Trunk Fuse. So thats what caused my Exhaust fuse to blow... Yeah Boy let me tell ya its MY fault for no knowing how to wire.....ANYWAY, got it back yesterday evening after an ass chewing. TODAY it blows the same fuse 2 times. I hit um GM, "Hey man you know how its my fault? Well your the damn car just did it twice more." He Said "Well you got a short." ( NO ****!!!!) So I say " yeah and its for yall to find, and it will be under warrenty cause I havent touched that system. Also if you give me anymore lip about stuff im not doing I have the corp. number right here infront of me and have already spoken with them once." Yes Sir bring it in tommrow morning. I was pissed can you tell? So we shal see if that made a diffrence to my stealership. Oh also they tried to say my motor mounts that arnt on the car anymore are the problem. it shook the car to much and cause damage....
im in the basin. and for some dumb **** reason my dealer has a contract with the other dealers that says i cant take it to another gm dealer withen 50 miles. Damn Lithia Crooks
evaporative emissions is the vapors from your fuel system. it has nothing to do with exhaust.
if you have a code for a solenoid its usually the solenoid, wiring or a software issue.
take it to your dealer and get them to test the solenoid for you.
#36
The EVAP system is not part of the exhaust system. However it is one of the systems tested and required to work properly for your car to pass hydrocarbon emissions tests.
Read this so that next time you can at least sound like you know a small amount when you open your mouth...http://www.autoshop101.com/forms/h62.pdf
Dude it's not your O2 sensor shorting out. There's a solenoid that is part of your fuel system the helps purge the gasoline fumes from the gas tank into a charcoal canister and then into your intake instead of out into the open air. If you jack up the rear end of your car and look by your gas tank there will be a black box with I believe a hose going to it (I believe it has a red fitting) and and electrical connection. The electrical connection attaches to the solenoid that's throwing the CEL. Why it's throwing the CEL is something we can't diagnose over CSS.net...
Last edited by Tazmanian_Dvl; 11-16-2008 at 09:34 PM. Reason: Automerged Doublepost
#37
Wrong!!!!
#38
Seriously?
Good to see you have the problem solved. Was it the cat not functioning properly?
EDIT - skipped the part about the O2 Sensor.
#39
#42
well then talk to a mod about it. but if its such miss info how did it fix the problem?
and yeah the pipe is way to close to the heat sheild and it rubbed the 02 wires and caused a short. there not much room in there
#43
Maybe he gave us the wrong code. The O2 sensor is not part of the EVAP system
and most certainly should have nothing to do with a solenoid in the EVAP system.
P0443 = EVAP Purge Solenoid Valve 1 Control CKT
Last edited by Tazmanian_Dvl; 11-16-2008 at 11:09 PM. Reason: Automerged Doublepost
chris88z24
08-23-2015 06:01 PM
09turbobalt
06-06-2013 05:05 PM
