part fell into intake manifold
Old 01-09-2012, 06:45 PM
drumrush's Avatar
already did, and nothing came out. and i cant find it anywhere else, which makes me think that its stuck inside somehow
Old 01-09-2012, 06:58 PM
drumrush's Avatar
so if i cant shake it out, is it a fair bet to say that its not in there? or should i assume that its stuck
Old 01-09-2012, 07:57 PM
drumrush's Avatar
i took a bent piece of metal and scraped around inside, didnt feel anything. then i took a little mirror and attached it to the end, didnt see anything. so im assuming that its not inside. lets pray im right
Old 01-09-2012, 09:47 PM
zerosk8ter83's Avatar
make sure your 100% sure before you put it back on,it could be stuck from the oil`gunk left in the mani.Take out the cores and you get a better look inside
Old 01-09-2012, 10:43 PM
bluebalt07's Avatar
That was gonna be my suggestion too
Old 01-09-2012, 11:36 PM
drumrush's Avatar
How do you take em out?
Old 01-09-2012, 11:40 PM
drumrush's Avatar
How do you take em out? I'm pretty drunk right now lol
Old 01-09-2012, 11:41 PM
you just get something to grab them and pull .Its gonna be a B to get them out
Old 01-09-2012, 11:48 PM
bluebalt07's Avatar
Take the end plate off along with all the seals and washers. Get a cloth of some kind to protect them and grab them with channel locks and pull. They take a fair bit of force to pull out but they slide straight out. Also gives you the chance to clean them up a little
Old 01-09-2012, 11:50 PM
nhanson's Avatar
Just soak that bitch in a bucket of dawn water
Old 01-10-2012, 12:36 AM
  #36
ItalianJoe1's Avatar
Turn them first with the pliers to break the seal that the o-rings have, that's what makes them such a bitch to get out. Once you do that they should pull straight out fairly easily.
Old 01-10-2012, 01:35 AM
  #37
insylem's Avatar
While you have it off, you might as well do the dual pass endplate mod, and install the ZZP Pheonalic spacer.
Old 01-10-2012, 02:13 AM
  #38
heathkidder's Avatar
what metal cylinder are you even talking about i need to be warned lol
Old 01-10-2012, 02:14 AM
  #39
insylem's Avatar
They are takling about the Laminova cores. Just be careful pulling them out, they are easily damaged/bent.
Old 01-10-2012, 02:17 AM
  #40
oh ok got ya iv only got one on mine to worry about lol
Old 01-10-2012, 02:21 AM
  #41
ujustgotshook713's Avatar
Just turn the key, youll know if she's in there
Good luck
Old 01-10-2012, 02:01 PM
  #42
drumrush's Avatar
i took the manifold back off, and took out the laminova cores. i still didnt see anything inside after looking around real good so im convinced that its not in there. i had everything put back on in less than 45 minutes which is a new record for me, and the test drive went great. the new coupler made a big difference
Old 01-10-2012, 02:09 PM
  #43
glad to hear it, drumrush! must have just fallen ONTO the engine, not IN it
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
patooyee
10-15-2015 05:11 PM
09-27-2015 08:53 PM
09-26-2015 06:44 PM
Quick Reply: part fell into intake manifold
