part fell into intake manifold
i took a bent piece of metal and scraped around inside, didnt feel anything. then i took a little mirror and attached it to the end, didnt see anything. so im assuming that its not inside. lets pray im right
Take the end plate off along with all the seals and washers. Get a cloth of some kind to protect them and grab them with channel locks and pull. They take a fair bit of force to pull out but they slide straight out. Also gives you the chance to clean them up a little
#42
i took the manifold back off, and took out the laminova cores. i still didnt see anything inside after looking around real good so im convinced that its not in there. i had everything put back on in less than 45 minutes which is a new record for me, and the test drive went great. the new coupler made a big difference
