Partial list of 2006 Cobalt TSB's Technical Service Bullitens
Old 08-21-2006 | 06:00 PM
Forseti's Avatar
Recommend this becomes a sticky....
This was taken from:
http://www.chevroletforum.com/recall...r_2006/TSB.htm
2006 Chevrolet Cobalt
Bulletin #: 3688
Sequence #: 10017263
Date: 01/01/1901
Component Name: 134000 visibility:sun roof assembly
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Sunroof switch bezel falls from the headliner. *tt
Bulletin #: 050232005A
Sequence #: 10017497
Date: 11/01/2005
Component Name: 010000 steering
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Ei05093 - clunk in steering system at slow speeds while turning and/or driving over bumps. *tt
Bulletin #: 050138016
Sequence #: 10018663
Date: 11/01/2005
Component Name: 353600 equipment:electrical:air conditioner
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Water leaking on front passenger side floor of vehicle, water blowing out of vents (seal heater core cover). *nm
Bulletin #: 3421B
Sequence #: 10014807
Date: 01/01/1901
Component Name: 110000 electrical system
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Engine stalls, loss of electrical systems, and no diagnostic trouble code (dtc). including 2005-06 pontiac pursuit. *tt *sc
Bulletin #: 3641A
Sequence #: 10018563
Date: 01/01/1901
Component Name: 022000 suspension:rear
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Rear suspension squawk/squeak over bumps. *tt
Bulletin #: 3687
Sequence #: 10016948
Date: 01/01/1901
Component Name: 020000 suspension
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Clunk noise from front of vehicle during turning maneuver. *sc
Bulletin #: 3757
Sequence #: 10018645
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Sunroof inoperative binding or stuck. *tt
Bulletin #: 050601027
Sequence #: 10017819
Date: 09/01/2005
Component Name: 060000 engine and engine cooling
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Revised camshaft position actuator fastener installation procedure. *tt
Bulletin #: 050730015
Sequence #: 10017537
Date: 06/01/2005
Component Name: 103000 power train:automatic transmission
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Hard to shift or select vehicle gear, shifter sticks/binds/jams. pontiac pursuit (canada) 2005-2006. *tt
Bulletin #: 050730016
Sequence #: 10017512
Date: 11/01/2005
Component Name: 103100 power train:automatic transmission:control module (tcm, pcm)
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Transmission control module (tcm) shorted to battery voltage during diagnosis and/or service. *tt updated. *nm
Bulletin #: 05083
Sequence #: 10017079
Date: 08/01/2005
Component Name: 353500 equipment:electrical:navigational system(global positioning system)
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Onstar system inoperative. *sc
Bulletin #: 05084
Sequence #: 10017470
Date: 09/01/2005
Component Name: 121000 exterior lighting:headlights
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Daytime running lamps inoperative - customer satisfaction program. *tt
Bulletin #: 050850011
Sequence #: 10017498
Date: 09/01/2005
Component Name: 221700 seats:front assembly:seat heater/cooler
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Revised front heated seat control module replacement. tt
Bulletin #: 050864030A
Sequence #: 10017765
Date: 11/01/2005
Component Name: 162300 structure:body:door
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Interior door handle inoperative or clicking noise heard when opening door. *tt update. *nm
Bulletin #: 3261B
Sequence #: 10018551
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: (retained accessory power) rap deactivates from drivers door only. *tt
Bulletin #: 3310D
Sequence #: 10017261
Date: 01/01/1901
Component Name: 061000 engine and engine cooling:engine
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Service engine soon (ses) light due to a p0171 - inspect air intake and oil dipstick. *tt
Bulletin #: 3385A
Sequence #: 10016549
Date: 01/01/1901
Component Name: 115000 electrical system:fuses and circuit breakers
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Repeated park lps fuse open (additional information). *tt
Bulletin #: 3393A
Sequence #: 10017006
Date: 01/01/1901
Component Name: 120000 exterior lighting
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Backlighting is inop during daylight conditions (headlight switch turned on manually) *sc
Bulletin #: 3433
Sequence #: 10017032
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Service engine soon (ses) light and severe engine misfire on cylinders 1 and 4 or cylinders 2 and 3. *tt
Bulletin #: 3506A
Sequence #: 10018530
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Incorrect mileage displayed after programming a new bcm. various models including 2005 - 2006 pontiac pursuit (canada only). *tt
Bulletin #: 3512B
Sequence #: 10016533
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Service engine soon (ses) light due to a p1182 diagnostic trouble code - potential causes and issues. to include 2006 saturn ion. *tt
Bulletin #: 3562C
Sequence #: 10018539
Date: 01/01/1901
Component Name: 063000 engine and engine cooling:exhaust system
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Service engine soon light due to p0420 diagnostic trouble code on low mileage vehicles - update ecm calibration. *tt
Bulletin #: 3627
Sequence #: 10018624
Date: 01/01/1901
Component Name: 071110 fuel system, gasoline:storage:tank assembly:filler pipe and cap
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Fuel tank is slow to fill and/or dtc p0446 - inspect evap vent pipe. the ses lamp may be illuminated due to a p0466 dtc. *tt
Bulletin #: 3628
Sequence #: 10018543
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: P2431 diagnostic trouble code after ecm replacement - inspect ecm part number. *tt
Bulletin #: 3635
Sequence #: 10016534
Date: 01/01/1901
Component Name: 036000 service brakes, hydraulic:antilock
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: No communication with anti-lock braking system after ebcm replacement. to include 2006 chevrolet hhr. *tt
Bulletin #: 3642
Sequence #: 10018533
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Ses light with a p0230 dtc and no performance concerns - replace ecm. *tt
Bulletin #: 3644
Sequence #: 10018532
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Momentary sag on light to moderate accel when cold - valve deposits. *tt
Bulletin #: 3646
Sequence #: 10018604
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Ses light due to dtcs p1516 and p1682 - ecm calibration pending. *tt
Bulletin #: 3648
Sequence #: 10018915
Date: 01/01/1901
Component Name: 114100 electrical system:wiring:front underhood
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Hesitation on acceleration after internal engine repairs - check injector harness orientation. *tt
Bulletin #: 3673
Sequence #: 10019203
Date: 01/01/1901
Component Name: 185000 vehicle speed control:cruise control
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Cruise control inoperative and/or malfunction indicator lamp on with diagnostic trouble code p0833 stored. the condition may not be able to be duplicated by the dealer yet the consumer may have a repeat concern. *ak
Bulletin #: 3786
Sequence #: 10018600
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: No start after engine harness replacement (non-abs). *tt
Bulletin #: 3799A
Sequence #: 10019210
Date: 01/01/1901
Component Name: 141100 air bags:frontal:sensor/control module
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Sir light on/service air bag warning message with diagnostic trouble code b0081. *ak
Old 08-21-2006 | 06:37 PM
Dante915's Avatar
so many tsb's so little time
Old 08-21-2006 | 08:42 PM
SuperTom's Avatar
The sad part that's not even all of them!
Old 08-21-2006 | 08:47 PM
SS SCHGD's Avatar
So the RAP feature is supposed to stop with the opening of the Passenger door too? And if you don't like day time running lights they will turn them off?
Old 09-09-2006 | 01:19 PM
SSinPhilly's Avatar
are they for the 05 too or just the 06?
Old 09-09-2006 | 04:48 PM
d_backer1's Avatar
WTF Sounds alot like the problems on the '05...but they arn't listed in the '05 tsb only the headlights to GM
Old 10-15-2006 | 05:02 PM
XenSS06's Avatar
where on the web can we go to see all the tsb's
Old 01-28-2007 | 05:19 PM
NOS2006's Avatar
Now, if I were to take my car in for a few of these TSBs, Chevy would fix them all free of charge, correct? I've got an '06 SS/SC with only 2600 miles.
Old 08-12-2007 | 02:41 PM
foreverchevy's Avatar
can't find any info for the rotors - have 2 06 g85 cobalts - both have warped rotors - victory red turned once by dealer has 8500 miles - rally yellow has 22000 turned twice by dealer - they all seem to be of inferior quality material but can't find tsb - i know there are more of u that have same problem we need to force gm to do a recall and get it right - have never seen rotors scored so bad so soon - they will never last 100000 miles
Old 08-29-2007 | 01:00 PM
mikeblackSS's Avatar
I had mine turned at 540 Miles !!!!!!!!!!!!!!!! And they were right back scorred and Warped with a few hundred miles. I said screw it......eventually just going to replace with slotted and cross drilled. '06 SS/SC Black
Old 08-29-2007 | 02:06 PM
Redberet's Avatar
These are TSBs, not recalls. They will fix them if you have that specific issue, and usually only if its under warranty. A Recall is different, under a recall they fix all the vehicles so they don't ever have the issue. Recalls are more safety related.
Old 06-01-2011 | 09:46 AM
06SS/SC-RED's Avatar
My 06 SS/SC has all of these problems except for 4 of them! it also runs rough and the check engine light has been on for about 6 months...no mods...selling it and looking for a car that runs! and that the bezel doesn't fall from the headliner when i go over railroad tracks..every time!
WhineSSbaby
09-01-2020 01:39 PM
satisfied
10-19-2015 01:35 AM
jonnycat
09-19-2015 01:58 PM
ROADKONE
09-09-2015 03:32 PM
lsjunior
09-04-2015 11:23 PM
