Pass. door goes "pop!", how/why?
I've had this problem for about the past 3 months. I figured since it was winter, that the door popping was just something that was cold or needed lubed. Well today my dad and I decided to have a look at it and it turns out it's actually rubbing against the fender.
Right where my black/red circle is at, that's where its rubbing and making the popping noise. Once it gets warm we're gonna take the side skirt off and see if a bolt or something is loose or whats pushing it out. Anyone have any ideas as to what happened to make the fender shift? I've never, ever hit anything too so nothing should have shifted.
Thanks!
Thanks!
Maybe someone hit you very lightly and pushed it in? Should be an easy fix, if not just put a little tip of electrical tape in the inner side and it might help with the rubbing until it falls off lol
I forgot to mention, we actually did the "grab door and rock" thing. The hinges are solid. My dad got the idea to put like 2 tongue depressors in between the door and the fender and then close the door slightly. It was just enough to push the fender outwards and not pop/rub as loud. We're still gonna look at it when it gets warmer out, but until then this will be good enough.
i had it and fixed it. 2 bolts behind the side skirt. Loosen the back one, open the door and put a wood shim where the door rubs, close the door, tighten the bolt back up. fixed for me, perfect as of 5 days.
