passenger airbag cover rattles horribly
Anyone have any ideas how I can secure this panel? Is it even safe to try to remove it, or is it even removeable? I'm not sure what I would do once it's off, maybe I could put a little square of dynamat near the noisy part if there is enough clearance between it and whats underneath? I don't have too many options because it is an airbag...... I'm still within warranty, should the dealer fix it?
I'm going to try to keep from getting irritated at that answer....instead I'll ask the question differently: Would the dealer fix this under warranty?
I get the same thing man, if I shift into second without running first to over 3k rpms, the low rpms into second gear rattles that thing for a second. It's annoying, but it's not uncommon. In my GF's old saturn the whole goddamn dash started to rattle after about 30k miles. It's the plastic GM uses, it sucks. Good luck getting a dealer to fix it, unless you have a really super cool service manager.
