passenger door wont open!!!
this week i tried to open my passenger door and it wont open... when i try the handle is look like nothing is atach to it... my lock is working
the same thing hapen to me last summer but it was on garanty... im not on the garanty anymore and i dont know how they open the door!
try searching on here, im pretty sure i have seen a few threads about this.
https://www.cobaltss.net/forums/sear...archid=6049796
^^there you go hopefully this is some help
If your door wont open hit it from the outside or inside to free up the latch Or drive around on bumpy roads <<<it works trust me!
After you get it open spray lube in the latch, if that doesn't work then remove the door panel push it up just a little & it should work....then lube the hell out it!
