Passenger side grinding/rubbing noise
Just started after I sprayed my rims. When making a hard over turn to the right about 3/4 of the way into the turn I get an intermittent grinding/rubbing noise. I doesn't do it every time either. If I'm going pretty slow it doesn't make noise at all during the turn. Sometimes even taking a corner with some speed it doesn't do it. So I'm confused.
I checked it out and took the wheel off and can't see where anything would be rubbing or grinding. There's no indications metal on metal contact or tire contact or anything like that. I've read that sometimes the suspension makes grinding noises when its going bad, so I guess that could be part of it?
Any ideas?
Any ideas?
DANRICKARD
10-01-2015 12:08 AM
